Idle NVH and Road NVH
vibrostics
Automotive
Mar 28, 2007
25
Please explain the basics of the Idle NVH and Road NVH. What kind of targets to be met for each of them and the criterias to meet the same.
Idle NVH
Max dB Lin (typically dominated by firing order)
Max dBA
Max steering wheel vibration (may be dminated by first order of firing order or misfires (half order)
Max floorpan vibration
Road NVH
Smooth Rd NVH - dBA
Coarse road NVH - max dBA and dbLin spectrum
Also various shake targets
Cheers
Greg Locock
SIG:please see FAQ731-376 for tips on how to make the best use of Eng-Tips.
Thank you. Please explain me more about how the floor pan vibration is so important than any other panel noise radiation/vibration ans also about the various shake targets.
OK.
It'll cost you $200 per hour plus business class flights and accomodation.
Cheers
Greg Locock
Agreed. Target setting requires as much knowledge and experience as subsequent work to meet those targets. Even more so if those targets are "sound quality" targets, which is becoming more and more important with modern platform sharing.
- Steve
Thank you for the responses.
Greg, you are correct. It is a hard earned knowladge.
