I work in Quality Assurance for an Aftermarket Clutch Manufacturer. One of my duties is to test samples against various specifications and approve or deny them based on the results.
One step of the testing requires me to disassemble a clutch cover to see whether the pressure plate is cast iron or ductile steel. The process is to either drill out the rivet or grind off the straps, both of which are time consuming and present availability problems (regarding the drill press). What I am looking for is a non-evasive way to test the plate. Is there a non-hazardous chemical that can be applied to a small section that would react with the metals differently? A hardness test has been suggested, but the availability issue applies.
I would appreciated and comments/suggestions on this idea.
I would appreciate if a brief explanation as to why or why not is included.
Thanks,
K. Smith
Quality Inspector
Thanks,
K. Smith
Quality Inspector
