rizzy77boy
Materials
We carburize small parts (rollers for bearings) in a rotary batch furnace using straight natural gas as the carbon source. We oil quench directly from the 1775F carburizing temperature. We then reheat to 1525F and drop quench in mineral oil. Tempering is performed at 360F. The attached micrograph (picral etch) shows the surface structure we saw in a small roller (approx .5" dia) made from 4320 VAR steel. At the surface, we typically see martensite, significant retained austenite, and fine dispersed carbides. I am not sure, however, about the fine black needles. How would you describe this microstructure?
