I’ve yet to see a logical multiple function device (MV) transmitter identification written anywhere. I propose the following for transmitters NOT doing flow calculations:
UT-xxxx for a MV utilizing HART communications.
UIT-xxxx for a MVT utilizing HART communications with a LCD readout.
UTN-xxxx or UTX-xxxx for a MV utilizing MODBUS or Fieldbus communications.
UITN-xxxx or UITX-xxxx for a MV utilizing MODBUS or Fieldbus communications with a LCD readout.
I have seen someone try to use ‘FPTT-xxxx’, but I do not think that is correct…
If the MV is also doing flow calculations, I propose UQITN or UQITX as examples.
I would appreciate your learned opinions.
Mike
Mike
