IDEAS Drafting - Hexagonal Circles 1
LeeRees
Automotive
GB
I am creating a drawing that includes circles (holes etc). However, the circles are comming out on the screen as hexagons almost like the resolution isnt high enough or something. They are also printed like this as well.
See link for screen shot.
Can anyone suggest a solution to this?
I am using IDEAS 5 m3, on sun/solaris system. I am using a Sun Ultra 45 workstation.
Many thanks in advance for any advice.
Lee
You need to set your hidden line processing to precise.
Select your view and click on view properties or just type in vs
Then select the second icon from the left
See pic
Then YOu will see a Bar that says either fine,mendium or coarse hidden you need to hold this down and go to precise. Then update your view
 http://files.engineering.com/getfile.aspx?folder=067422c0-1d24-42eb-8274-be0eba5c379d&file=HIDDEN_LINE_PROCESSING.JPG
Sorry you can set this setting in your drafting.in and or drafting.mm
This is in your user directroy
This is the line you need to find in your masterdrafting.in or masterdrafting.mm
hidden_line_processing_option=4
Your is probably set to 1-3
it needs to set to 4
many many thanks for the responses, this has solved my problem.
Lee
