Imran Structural Engineer
Currently I'm working on design of bridge with integral pier. Usually, for typical non-integral highway bridges with pile/column bent pier, it is practice at our office to assume K value of 1.2 in bridge's transverse direction and 2.1 in longitudinal direction (AASHTO Table C4.6.2.5-1) when fixed at bottom. However for integral bent type, even though the manually calculated value comes below 1.2, should I safely assume value of K to be 1.2 for both directions?
Thank you.
Thank you.
