spdracer22
Automotive
- Feb 16, 2005
- 32
I'm an auto/mech engineer, and have only had a couple circuits classes, so please forgive me if I'm talking out of my you-know-what. But, easily-integrated 'green' power generation interests me, so here I am, trying to learn...
When a solar panel or wind turbine is added to a home, it's either:
A) Connected to the main supply, allowing all loads to feed off of it, and feeding any excess to the grid. It may have a battery bank between the generator and main.
B) Somewhat like a UPS. Charge a battery bank that feeds a few devices directly, then switches to main when bank dries up.
The idea:
Somewhat like B, only without the batteries. There would be a box that the load device(s) and generator would be plugged into, then the box would be plugged into a standard 110V wall outlet. 100% of the generated power would be used all the time, which would be supplemented by the wall outlet. So, for a 100W load, 10W may come from the solar panel and 90W from the wall, etc, etc.
So, my questions are:
1. Does anyone know of a company that builds such a device?
2. How would one go about building such a device? Is it as simple as just putting the supplies in parallel?
3. Or, is a better/simpler way just to invert the generated DC into AC and plug into a wall outlet? (I've heard this is a bad idea, but thought I'd throw it out there anyway)
The idea:
