Yes, you can. In the 2008 SDPWS this is stated in section 4.3.3.3. As long as the grades, nailing, etc are the same then the capacities can be doubled. If the grades, nailing, etc are different, you can only double the lower value. Make sure you take into account the wind reductions though in the table the same for both sides.
PE, SE
Eastern United States
"If a builder builds a house for someone, and does not construct it properly, and the house which he built falls in and kills its owner, then that builder shall be put to death!"
~Code of Hammurabi
