I am facing a frustrating situation and would like some insight from some other folks. Three years ago I designed an HVAC system for a church school. It was a two phase job: classrooms and gymnasium/cafeteria. The first phase was built immediately and the second was deferred until more funds were raised. Back then we were designing under the Southern Building Code (SBC). The SBC referred to ASHRAE for ventilation rates. Under ASHRAE I could reduce ventilation amounts based on time of occupancy. This in turn allowed me to lower the cooling tonnage.
Now the church wants to move forward with the second phase. Since we have switched to the International Code, the architect asked me to research how the job will be impacted by the new code. When i reviewed the ventilation requirements, I found that IBC doesn't reference ASHRAE at all. Nor does it allow for the reduced ventilation for transient occupancy. I found that the cooling load will approximately double - just for the ventilation load. As the original design was the basis for the budget, I don't see how the church can affrod the added tonnage.
Has anyone else run into this problem? Why doens't IBC leave the ventilation requirements up to ASHRAE guidelines?Any advice would be appreciated.
