i2c bus micro temp sensor problem
mcgyvr
1,457
see attached schematic (only a portion to protect the design)
Just started production runs on a microprocessor unit that goes into one of our products.
We got 5 boards done on a quick turn for orders we have in house already.
We fired them up to test them and found that after about 2 minutes the U7 chip (TC74 temp sensor "onboard") seems to stop functioning. (It displays the temperature on the LCD screen for about 2 minutes then the display turns to "--" (which indicates an error or no input from the temp sensor).
We think we have narrowed it down to a hardware issue as the prototype boards (same pcb layout/components) when programmed with the same new firmware do not have this problem. eeprom/temp chip and 2 external temp sensors (same chip) are all on the same I2C bus. The 2 external temp sensors do not work at all. All other analog inputs work fine. SCL1 and SCL2 on the schematic go to 2 other I/O pins on the micro. If you power down the unit and wait for about a minute or so and fire it back up the temp is displaying correctly again until the 2 minutes or so is up and it cuts out again. If you turn it off and right back on again after failure the issue is still there.
I was just wondering if you could think of any issue that might cause this. It just seems funny that it works fine for about 2 minutes then just stops.
Also the 2 external temp sensors do not display a reading at all anytime even when the onboard temp is working.
I don't have access to a scope/LA right now but should have one in a few days.
The company that designed this for us has gone belly up and is of no help.
So many things this could be, without a scope/meter it's difficult to narrow down.
Is sclk still getting a signal after it fails? Is the SDA line being dragged high/low permanently by another chip? Can you separate those other chips from the control lines for testing? Is the voltage stable? Is the I2C controller hardware-based or software, and if software-based, are you sure of the design? Do you see current draw increase after it fails? Is your power supply strong enough?
Dan - Owner
I'll answer what I can.
1-voltage seems stable 3.298v right at startup 3.278v around the time the device stops.
2-IIC controller is hardware based built into the micro I believe (micro is Freescale MC9S12NE64VTU)
3-Do not see current draw after failure.
4-Power supply is strong enough.
Like I said all the hardware side (power supply,etc..) was working just fine in proto's. No power issues that I know of.
I will try and see if I can remove all but the TC74 and eeprom from the bus for testing.
Could the EEPROM be hanging up any of the bus lines? Is it continually accessed throughout operation or intermittently? Is there a pattern between EEPROM access and failure of the temp units?
Dan - Owner
I found the problem (with my very limited electronic background)
R22 was a 100 ohm resistor and not a 1K as it should have been.
I am very proud of myself..
I feel bad for the assembly house who now has to go back and replace 3500 SMT resistors.. Seems their purchasing person missed a 0 when purchasing the parts.
Thanks for your help
Yes thats how I figured out the problem.
I was trying to answer/understand your other questions and BAM there it was... wrong pull up resistor
