I've played with DesignStar to evaluate it. Really nice for solid objects, but I tried to do a .09" thick sheet with angles welded to it as stiffeners with shell elements. I tried several diffent approaches but never got what I wanted. What I don't like about is if it doesn't mesh your geometry like you want, for instance in my case it left out the surface immediately adjacent to the angle, you can't go in and generate elements your self.
I agree with swertel, when it does work it's so easy a monkey could use and I'm not sure I would trust a monkey with FEA.
By the way, you said "COSMOS/M for Pro/E". I just assumed you really meant DesignStar. That's the package that you can import a geometry from a solid modeler like Pro/E and it will automatically mesh it and associate nodes with surfaces, edges, etc. You can import geometry into COSMOS/M but generating the model is much more "manual" than DesignStar.
