I need to finish the design of an air plenum, which is actually a distributor of air. This plenum is 4.200 mm long and 146 mm wide, and would have the final shape of a long and narrow oblique parallelepiped. Along the length, on one of the walls only, I have a series of 400 orifices with 9 mm diameter, stamped as Venturis, which will allow the air to be blown over a paper tissue which needs to be dried. Hot air needs to go into the plenum at 130 C. Air velocity on the orifices is rated at 25 m/s. Considering that I have to feed 0.636 m3/hour of air through the Venturis, what is the recommended section of the plenum on the infeed side? Should I work with which air speed at the entrance in order to guarantee the uniform pressure in the plenum to provide uniform air speed through the Venturis along the length? What would be the ideal shape of the parrallelepiped?
