leopardforest
Hi all,
I need help choosing a accumulator or something else appropriate for my task.
I have a pumping system with approximately 5 gallons of oil in it. It is a closed system. When I run the machine the temperature goes up (200°C system max) and as the temp increases so does the pressure due to thermal expansion of the oil. Currently I have to bleed off fluid to stay within the pressure rating of the system and this is undesirable for what we are trying to do (we are a research lab).
I would like to be able to maintain the system pressure from 0-100 psi.
Be able to run the system up to 200°C.
Flow rate of the system is 10-30 gpm.
I was looking at a piston type accumulator as when we heat the oil in the system the volatiles in the oil boil off and I want to prevent this by having no headspace while still allowing room for expansion.
Most piston type accumulators are rated to several thousand psi which I don't need and are rather expensive.
Do you guys have any suggestions for accumulator or other options??
Thank you!
Thank you!
