robinairtechsupport
Automotive
i recently had an interesting experience that i would like to share, as well as maybe get some insight as to what exactly went wrong, though i believe i already know... 93 mazda protege, 1.8, single cam FI, I4 cyl, 16 v, gasoline engine, stock ignition, 67000 miles on the motor... just because i was bored one day, i decided to put a dual exhaust on the car... so i had some 1 7/8 laying around, and some 2 1/4,... and some 3 inch... so i took the 2 1/4, and flattened one side of a 4 inch peice, cut the angles on the 1 7'8, and made a perfect y pipe... from one pipe to two, perfectly transitioned, deburred with a die grinder for flow... 12 inches total, attached the 2 1/4 to the downpipe, stock exhaust manifold, out the back, about four feet of two 1 7/8 pipes welded together coming into the side of a six inch piece of three inch, cut and formed to transition into 1 7/8 to exit in front of the rear tires... i thought that hitting that "T" would create enough back pressure, but i believe things went horribly wrong because of inadequate heat transfer...end result...HOLES BURNED AROUND MY EXHAUST VALVE SEATS, INTO THE PORTS, ZERO COMPRESSION, ALUMINUM DEPOSITS ON THE PISTONS. i wasnt driving it at the time, but the ignition was not excessively advanced, and it was not running excessively lean, wich leads me to believe it was the exhaust, not detonation, though detonation may have occored once the metal started melting. any thoughts???
