Yayyyyyy ! ...Pictures !!!!! And tank volumes !!!! ......My, my my !!!!.... An OP so generous in details !
How about a few dimensions !????!!! No more use of vague words like "over there" and "big" and "open area" !!!
A few notes and personal opinions on your design.
- I believe that you are elevating the tanks to enable gravity feed (dump) to the influent water. Are you trying to eliminate pumps and is this what you want ?
- Elevated tanks implies some type of pressurized tanker delivery of chemicals OR two dedicated fill pumps from grade.... Is this what your delivery is and is this you want ? Is this compatable with your design ?
- Please specify strengths of acid and caustic. Will you be storing the easy to handle 50% caustic ?(like everybody and their brother does)
- You may want to have washdown (potable) water available at the tank elevation. If the facility were to be built in the USA or the EU, a safety shower would be required at the tanker unloading level AND at the elevated tank platform. (
- In order to put fine control of water pH, many plants use metering pumps to precisely control the amounts of acid and caustic. If you intend to do this, there is no reason to elevate the tanks... IMHO
Tell us more about your design ....
MJCronin
Sr. Process Engineer
