I have a question about vacuum pres
vono
19
I have a question about vacuum pressure differential ...so I have a pipe connected to a chamber with a thin beryllium window separating them and on the pipe side the vacuum is 1x10 - 4 torr and on the chamber the vacuum is 1x10 -7 torr . So I would calculate there is a difference of 1x10 -3 torr . If this is correct then how much force is pushing on that window if that window surface is 1" x 0.5" rectangle?
J
School / college question?
Why don't you say what you think and then ask if its correct.
Hint - work in consistent units then force = pressure x area is a good start point
Actually your PD is incorrect.
Its a pressure difference, so its 1 x10-4 - 1 x 10-7. pretty damn close to 1 x 10-4....
Think of it the other way around. If you had one side at 1 x 10^4 (10,000) one side and 1 x 10^7 (10,000,000)the other, the difference wouldn't be 1000 would it??
No school question..... it is only part of an issue I have pertaining to the direction of said window... I have a beryllium window that has a vac side and a atm side and if the vacuum pump fails on the vessel side I need to know if the window will hold and also I need to know the force during normal use.
Not very much.
1x10-6 pounds
using the correct pressure differential.
Somehow someone forgot to stay awake in their high school algebra class.
Fell asleep in the maths class before that....
Do you know how to calculate force if you know the net effective pressure (vacuum) and the applied area?
Little Inch told you the answer to this question in the first post:
" Hint - work in consistent units then force = pressure x area is a good start point "
I think he means the glass has sides which are rated for vacuum and atm.
je suis charlie
