I am a Mechanical/Automotive Engineer, though I have recently been given some structural work. I will try to keep this as short as possible. My company purchased a new CMM machine which came with an I-beam mounted trolley for loading. The max load on the trolley is 2000 lbs. The I-beam is to be mounted underneath an existing 3" thick concrete floor. The floor joists are 3 ft. apart and are I believe 4" wide I-beam. The I-beam will be simply supported at one end by an outside concrete wall, and than welded to each floor joist. The other end of the beam will overhang the last joist by approximately 3 feet to gain the necessary travel of the crane. The question is, what type of deflection am I allowed at the overhanging end of the beam? There are no standards for this application that I know of. Also, what type of deflection would be allowed on the flange of the I-beam due to the mounting of the crane? Any help will be greatly appreciated.
Thanks in Advance
Steve
Thanks in Advance
Steve
