Steel fibers can provide tensile capacity to concrete, but not in the concentrations and mixing methods typically employed at ready-mix plants. It takes a much higher volume of steel fibers, and a much more precise method of adding the fibers to the mix, to provide even distribution. Not to mention, a much more involved testing regimen, to ensure the tensile capacity has been achieved. All in all, it's much more expensive than using conventional reinforcing. The tensile strength is typically a side effect of the required ultra high compressive strength required in the specialty applications for which it's used.
