Mountainrunner
- May 25, 2020
- 8
I am aware of diaphragm shear values for plywood nailed directly to rafters
I am aware of diaphragm shear values with 1x solid lumber nailed to rafters
but...
I don't know of any lateral shear values for plywood over skip sheathing
any suggestion...
I have a project owner wants to remove flat ceiling framing to frame a vaulted one (see attached sketch)...
however....the roof plywood is not nailing directly to the rafters but...it is nailed to skip sheathing...and...I don't know if there are any lateral shear values for such conditions...
is there are not shear values for such condition...could it be that the flat ceiling works as the diaphragm?
any advice/suggestion on how to address this..if owner insist in removing the flat ceiling framing...
but...
any suggestion...
