KiwiTanks
Industrial
- May 16, 2007
- 39
API653 Section 12.3 relates to the hydrotesting of a tank after major repiars and states "A full hydrostatic test, held for 24 hours, shall be performed...."
What is the definition of a "Full Hydrostatic test". I have a client who just wants to go for the minimum possible. The only references I can find relate to the maximum. My understanding is that a hydrotest should be a full as possible, stopping where limitations such as floating suction, floating blanket, over-fill, or structural limitations prevent further filling.
For example, is it acceptable to fill to the same height of water that would give the same stress in the lower strake as if it were filled with product to the normal fill level - even when there is approx 3.5m of shell height above this level?
!!??!!Help!!??!!
!!??!!Help!!??!!
