Mche:
As we both know, Hydrogen is the smallest molecule in the Cosmos. It will literally permeate through anything, if given enough time to do so. It goes through steel pipe walls and if you have ever operated and maintained a Hydrogen system, you will have experienced the fact that when you D&R (Demolish & Remove) old carbon steel Hydrogen piping, you cannot go in and burn out the pipe without first allowing the H2 soaked into the walls to evaporate out. If you don't, the pipe seems to "catch fire" when the cutting torch heats it up.
Hydrogen also has a negative effect on steel that is titled "embrittlement" - a process that weakens the parent metal to the point of failure. The higher the temperature and pressure of the H2, the more pronounced are the negative effects.
I don't have my materials library here handy at the moment but I recall that we were using a chrome-steel alloy on piping for H2 service back in 1970. There may be other aspects to H2 materials of construction that you should bear in mind, but those two particularly come to mind. I personally have always butt-welded all my H2 piping, reducing the quantity of flanges or possible leaks down to zero - if possible. If you have ever seen (it would have to be at night) a self-ignited H2 leak through a flange gasket, you will wind up doing the same. Hydrogen will always leak -to begin with- and what's worse is that the stuff has a negative Joule-Thomson value: it heats up when it expands. It also self-ignites with the expansion friction created and the leak catches fire. The way we found most H2 leaks in Steam Reformer units and Hydrogenation plants was to walk out at night and keep an eye out for the bright, whitish flame that H2 gives. You can't see it in the daytime and, in fact, we had an operator severly burned by walking on a catwalk besides a Hydrogen line where there was a leaking flange. He never saw the flame as he walked by and had his arm burned just as if it had been a cutting torch.
You are right on track in keeping your Mech. Engineers fed with as much process information as you can give them. They can only design the mechanical end to the same degree of information that they can gather on H2. Some of the M.E.'s should already know a lot of the H2 characteristics, but it's always wise to work together as a team to produce the safest, most flexible, and most cost-effective installation. There should be a lot of information out on the Web regarding Hydrogen piping, handling and materials of construction. I know books have been written on the subject. I can't come up with a list of them, but I know they have existed. I optimistically would expect some of my colleagues on this forum to pitch in additional or further information in accordance with their experience in this field.
I hope this has been of help.
Art Montemayor
Spring, TX
