HydroCad Exfiltration with Wet Ponds
ftroop82
I have a wet pond with the WSE of 36.0' and the top of the pond at 42.8', how would you calculate exfiltration with Hydrocad? The GeoTech report has an infiltration rate of 1.8 inches per hour.
I added the exfiltration outlet, but wasn't sure how to input the data. Do I use the only above invert since the pond is wet? Then do I use the surface area or wetted area?
