Hydroblasting cleaning
migueldiazch
Petroleum
VE
Is there a way to calculate the maximum pressure for internal pipe cleaning using hydroblasting (e.g. heat exchanger internal pipe cleaning)?.
If i understand your OP correctly there is really no maximum on an open tube where the pressure can't build up. If the tube is completely blocked again there is no limit if you keep the lance tip moving, in most cases rotating. If a tube is completely blocked if you let the nozzle get stationary you are subject to get a hole in the tube. Other consideration are the delivery tube size, tip size, automatic or hand controlled.
Can you comeback with a little more information about you particular conditions.
Thanks Unclesyd for your answer, it was pretty much what i was thinking.
Adding a little more general information.
Always use a mechanical means to handle any lance at pressure above 13,500 psig in a closed tube if possible in an open tubes. Human operators tend to pause and that is where you get into trouble.
I like to use mechanical means for any work above 13,500 psig due to operator error that could result in injury to himself or others. Above 13,500 psig there is eminent danger of someone being swiped by the jet and causing the person to suffer hydraulic embolism from the site. This not to say there isn't any safety concerns with lower pressure it means that the higher the pressure it takes more effort to keep everyone safe.
Always use the proper personal protective gear while hydroblasting.
