Hydraulics
amcd1998
Student
GB
I am currently studying hydraulics, but do not understand what we were taught today, could someone,if possible please give me a step by step of the circuit function. Your help would be greatly appreciated, thanks
I have attached the diagram below
 https://files.engineering.com/getfile.aspx?folder=e84f14a3-d14b-4350-ba87-ee73ca3500f7&file=Screenshot_2022-01-17-21-09-22-39_965bbf4d18d205f782c6b8409c5773a4.jpg
I think you copied the diagram incorrectly. The valve linked to the motor is set to dump fluid on the ground. It doesn't show where the switches are. I suppose it is intended to sequence an extend/retract cycle with operating the motor either before or after with a shift in motor direction. I also am unsure why there is a restriction on the motor; it's not an efficient way to regulate the speed; the way the diagram is set it will always be restricting flow.
Thank you for the reply, when Y3 is activated, the oil goes from the pump to the motor?, I have attached a photo of the diagram from the board which we were told to take down. I hope this helps.
 https://files.engineering.com/getfile.aspx?folder=209f4ea6-b465-4342-b5d7-3ca181d9e069&file=Screenshot_2022-01-18-09-20-42-15_965bbf4d18d205f782c6b8409c5773a4.jpg
Here is a photo that we were given of the circuit, hope this gives a better understanding, it may be difficult to see the components. Thanks for your help
 https://files.engineering.com/getfile.aspx?folder=bb743602-7e07-48f4-8545-97f8b41b14dd&file=Screenshot_2022-01-18-10-23-57-69_965bbf4d18d205f782c6b8409c5773a4.jpg
