Has anybody got a simple circuit for maintaining the pressure reasonably constant behind multiple tine cylinders, whilst accepting fluid (perhaps into an accumulator) when the ground conditions get harder and the cylinders are forced back. The pressure needs to be settable between 400 and 1400psi and the max allowable pressure is 1600psi. The fluid flow needed to be accepted is 2 litres. The flow supply is from tractor hydraulics.
thanks
thanks
