LaurenceSachs
Hi there,
I need to understand something that I hope you can help with!
I work with water powered machinery as well as pneumatic machinery and I have found that there are specific designs required for each instance. Obviously this is due to the incompressibility of water compared to air's compressibility.
Note: I have attached a quick drawing for reference.
The left hand drawing is of a pneumatic cylinder and the right one is of a hydraulic cylinder.
Now as you can see the pnuematic cylinder is common sense. The stroke is related to the length of the cylinder up to the exhaust where pressure is released. The air decompresses very quickly and so only needs a small exhaust at the end of the stroke for this.
However the hydraulic cylinder, the piston move even though there is no pressure difference in the second portion of movement where the cylinder enlarges allowing the water to flow over the piston.
Due to the fact that the water is "incompressible" the whole pressurised volume needs to be removed so that the piston can return to the start of the stroke.
How on earth do I calculate the force exerted by the water piston at the end of its stroke?
Is it related to momentum of the piston?
How do I calculate the correct length of the initial pressurised area?
Please help me understand this!!!
laurence
laurence
