Hi guys,
This is my first time on this forum. I wish I knew before about Eng-tips web site. Anyway, I am Engineering operator on a ship and I am learning the steering system. Looking at the manual and the technical drawing, I understand the entire system except 2 components in the system which are the "shuttle valve" and the 2 "Check-Q-Meters".
Let me explain the system more in details:
2 Hydraulic pumps are supplying the system, a main pump and a standbye pump. From the Directional valve, the flow goes to the "Check-Q-Meter" and also the shuttle valve (connected to the return line) . Then after the "Check-Q-Meter" it goes to your 2 steering motors and then the flow goes back to another "check-Q-Meters" and the the shuttle valve again (which is between the supply and the return side) and then back to the directional valve.
Garek
BC, Canada
Garek
BC, Canada
