Hydraulic diameter of finned tube
crinners
1
Hi I read post thread391-248736 and was interested by the post from 25362
25632 said:
Hydraulic equivalent diameter of finned tubes (dHe)
df = external diameter of fin
do = external diameter of bare pipe
p = face-to-face distance between adjacent fins
t = fin thickness
dHe = [(df2- do2)/2p + dft/p + do(1 - t/p)] ÷ [1 + (df - do)/p]
would anyone happen to have a diagram showing this more clearly? I was unsure as to what p would be as a distance, is this circumferential? and if so at which point of the fin?
There are mainly two types of pitches required for heat exchanger application:
One is called a streamlined pitch and the other is a transverse pitch.
I believe your equation is calculating the distance between 2 tubes in the transverse direction which is perpendicular to your stream-flow's path (on the shell-side).
Is your fin-tube's pattern in a parallel or stagger configuration?
Hope this helps.
Jack
Look at the 3rd drawing. (Note: it uses "s" instead of "p" for pitch, but it's the same dimension. I hope this clears up any confusion.
Want to know the do's and don'ts of Eng-Tips? Read FAQ731-376.
English not your native language? Looking for some help in getting your question across to others or understanding their answers? Go to forum1529.
