RRaghunath
- Aug 19, 2002
- 1,733
Normally, we are not comfortable with low / medium impedance bus bar protection schemes for HV switchyards though the RADSS of ABB has been in service for so long proving the dependability of the low/medium impedance bus bar protection schemes.
All those comprehensive numerical bus bar protection relays available in the market seem to be offering only low impedance bus bar protection.
Do you find any problem with the concept of High impedance bus bar protection using Alstom numerical relays such as KCGG or P122 (or ABB relays type SPAE or any other make relays, for that matter)?
I have worked with KCGG relay based bus bar protection scheme for 220kV switchyard. With regard to relay P122, I heard the same has some problems when tested with transients and was not acceptable at that point of time.
Thanks in anticipation.
