I know... another power quality monitoring thread. But please bear with me.
IT = Instrumentation Transformer (ie: CT, PT, VT, CVT, etc...)
So let’s assume we want to add some power quality/disturbance monitoring equipment at a HV station. This implies we are interested in getting information about harmonics, over voltage transient spikes, etc… that are happening on the primary of our power system. Now we are going to connect some kind of monitoring equipment to secondary IT circuits. Also, let’s assume we have both protection rated and metering rated IT circuits available to ‘hack’ into.
Our metering ITs will have a high level of accuracy, but are not robust and will quickly saturate. Our protection ITs are very robust but do not have a high level of accuracy. Given these considerations which circuits are best to use for power quality monitoring?
As I ask myself this question I start to contemplate the following:
1. Can metering ITs saturate for sub-cycle transient spkies?
2. What is the response time for transient and sub-transient disturbances of both metering and protection ITs? Is there a difference in response time between the two? Can this limit the monitoring resolution?
3. Knowing that during a fault situation, the protection IT is probably best suited to obtain information about the primary power system, as the metering IT is susceptible to early saturation, does this imply that I should use protection ITs for disturbance monitoring?
4. Can a secondary IT impose any limitations of Power Quality Monitoring?
After a quick search of previous threads on Power Quality Monitoring I haven’t seen these issues discussed. I apologize if these questions have been asked before. I would appreciate any insight people may have on this topic.
Thanks,
Mark
Thanks,
Mark
