The output of my dual variable p. supply goes from 1 to 45 V with a max. current of appr. 2A. Same specs for each rail.
The PICmicro in charge has to mannage the setting of current limitation requiring sensing of load current for each rail somewhere around the pass transistor.
When considering an opamp (diff. amplifier), to get the drop across the sensing resistor, measured wrt ground, I've found that:
a) Common opamps can not sustain working with such high input voltages (appr. 45 V). The uncommon ones that I could use are EXPENSIVE /HARD TO OBTAIN.
b) Every time I tried a differencial amplifier fed by a supply also feeding the circuit under measure, Vout was meaningless. With separate supplies (that is, separate commons) everything was fine.
My questions:
1 - How to sense current reliably, with Vout= 45V?
2 - Whatever is suggested, I need the same cirucit to sense current as reliably as above when Vout= 1V.
3 - If I solve question 1, I wonder if sensing BEFORE the pass transistor is better, since the Vin (even quite high)would be more or less always the same allowing to neglect problem in question 2.
4 - Is it any chance of avoiding an auxiliary supply (even small) for any differencial configuration?
5 -I think I fairly understand op amps to a certain depth but the necessity of separate supplies in differential amplifiers escape to my comprehension.
I browsed, several manuals, National's is one, and found no warnings on that. It seems that pros take that for granted.
I recall that for the LM725, there was a circuit which I reproduced with the mentioned surprising finding. Same surprise with the same circuit implemented with two OP77.
Enlightening replies will be appreciated. (Even more if you can follow the order of my questions!)
Muchas gracias
My questions:
Muchas gracias
