we have BOILER FEED PUMP MOTOR OF 300kw HT(3.3kV)directly connected to VCB.Recently after overhauling we are encountering an abnormal humming noise from the motor.Temp of DE & NDE side bearing is very normal as both side bearing has been changed & sleeving done at both side shied bearing housing.No trace of neither abnormal temp rise nor vibration.Checked both side bearings on loaded condition with bearing analyzer & found no issue with it.The noise decreases noticeably under decoupled condition.So,the only problem is to find the origin of the humming noise.
please feel free to ask for more information.
