ag89
- May 2, 2001
- 35
I have a few questions for the design of HSS.
1. Why are the property tables different for HSS in the LRFD design specification from the properties given in the AISC ASD 9th ed for TS sections?
2. In design, to allow for the torsional effects of eccentric loading, the LRFD spec combines the loads for flexural + axial + the square of the sum of shear and torsion (Eq 7.2-1). Can I use the same interaction for ASD, using stresses instead of factored loads? I am designing the structure using ASD.
3. The allowable stress in LRFD for torsion (this specific case) is 0.6FY. Can I use this allowable stress for torsion design?
4. Basically, from what I can tell, the equation for stress due to torsional loading is: f=T/C.
Any help would be appreciated. Thanks in advance.
