tribleprince
Senario-1
I have a tank of Volume = 4.19 Cubic meter which is filled with water. Thank has an opening of 200 mm (0.2M) at the bottom of the tank also known as Flood ports. I want to empty the tank by giving a HP air blow at 10 Bar. How much air is required to empty the tank completely.
If someone can give any formula or any reference that can help me.
Senario-2
I have a tank of Volume = 4.19 Cubic meter which is filled with water and the tank is dipped in water at a depth of 5 meter depth. Thank has an opening of 200 mm (0.2M) at the bottom of the tank also known as Flood ports. I want to empty the tank by giving a HP air blow at 10 Bar. How much air is required to empty the tank completely.
Senario-2
