May 8, 2003 #1 A akraitzer Guest Is there any option of creating an equivalent to extrude along vector, which is not normal to the sketch plane in Pro/ E ? This feature is very simple and usefull in I-DEAS, and Unigraphics?
May 8, 2003 Thread starter #2 G Guest Guest The basic feature is called a Sweep. A more advanced feature is the Variable Section Sweep (Var Sec Sweep).
May 8, 2003 Thread starter #3 D dougr Guest There are also: swept-blends where you can define different sections along the trajectory (vector). blends where you can vary the sections but the trajectory is always linear (general & parallel blends) or circular (rotational blends). With all of these except the swept-blend the sections are always normal to the trajectory and are always planar. With the swept-blend you have a pivot angle option where you can deviate from normal.
