how to use section view in drafting to hide the remaining geometry
godpaul
Automotive
NX 8.5
the attached picture is an example. real geometry has lots of features
i want to give a top view of the cap,
HOWEVER, I do not want to show the remaining geometry which is the big disc.
I sort of learn that section view option has "Foreground", "beckground" option, I follow the help file but still dont know how to properly get what i want.
as you see, I put the section view line outside of the geometry because i just want to show the top of the cap UP to the red dot line...
how to do this task in NX
View Dependent Edit is what you may wish to try.
Tim Flater
NX Designer
NX 8.0.3.4
Win7 Pro x64 SP1
Intel Xeon 2.53 GHz 6GB RAM
NVIDIA Quadro 4000 2GB
View Style → Section → Background(uncheck the box).
MZ7DYJ
Per the attached Drawing, select the view of interest, press MB3 and select 'Style'. When the dialog opens, select the 'Perspective' tab and toggle ON the 'Back Clipping' option and enter 100 for the distance (this may require some trial & error to get what you're looking for) and hit OK.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
 http://files.engineering.com/getfile.aspx?folder=bc95bb7c-d7ec-4268-8bcd-8ba2d8f671ad&file=sectionView_dwg1_JRB-1.prt
thank you John,
that works very fine!!
and also, thank you everybody
