How to update automatically drawing views 3
Pjone kenobi
44
Hi everybody,
I want to update automatically my drawing views when the drafting mode is activate.
I tried to find in the default user value but without result.
Do you have an idea? Maybe an NX open code with "ufspop" as the entry point?
Thanks a lot for your help.
Toggle off the customer default "delay view update". In NX11, it is in the Customer Defaults, Drafting, General/Setup, Customize your Drafting Standard, View, Workflow.
-Dave
NX 11, Teamcenter 11
Are you sure you want to do this? It will cause long waiting times for users.
Every time they make some small change the whole drawing will start updating.
Also when you make a change to a view which has details or sections attached.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX12 / TC11
@Dave, I saw it but it's not running:
@NutAce
Maybe you're right, I will see after one week using and will choose at this moment.
@Dave, @NutAce, Thanks a lot for your help
Best regards
