A simple test with a multimeter is to check gate resistance. If it seems to be OK, then the bulk of the silicon usually is. If you find non-continuity or a short in the gate circuit, then you can conclude that there is a fault in the thyristor.
Do this: Use an ordinary multimeter in ohms range. Measure resistance between the two wires (that is where the gate is). If resistance is below one or two ohms (these data are for large disk thyristors) or more than 1000 ohms, then you have a faulty thyristor. If it is somewhere between 10 and 100 ohms, then the gate is OK. If between 1 and 10 ohms, you need to check further - it is a grey zone where also gating on needs to be checked.
To check gating on (the ability to be switched on by the gating pulse) do this:
1, Locate cathode side (usually indicated by the thyristor symbol on the ceramic) and connect the negative side of a DC source to it (a mains adapter or battery or whatever you have available).
2, Set the DC level at around 12 V (this is not very critical, just about any voltage will work, as long as it is more than five volts).
3, Find an incandescent lamp and connect between positive side of DC source to it. Wattage is, again, not critical. Use whatever lamp you find, but make sure that the voltage corresponds to your DC source.
4, Connect other side of lamp to thyristor's anode. You need to apply a pressure similar to the pressure in the actual thyristor stack in order to get a reliable contact between anode side and internal silicon.
5, If the lamp is dark, then the thyristor is blocking, which is good. If the lamp lights up, then the thyristor is shorted (or you have made a mistake). If no mistake, then mark the thyristor as defect.
6, Check gating on. To do this, you need to identify the gate wire. One of the wires is the gate wire and one is the auxiliary cathode wire. The auxiliary cathode wire can be located by measuring against cathode. The one that is shorted to cathode is the auxiliary cathode wire. The other one is the gate wire.
7, When you have identified the gating wire, connect momentarily to the anode (NOT to the DC source, you need the current limiting lamp in the circuit so as not to kill the gate). The lamp shall light up and then remain on. If it does, chances are that the thyristor is OK. If it does not, you may have to try with a higher voltage or a lamp that has a higher wattage. The reason is that both gating current and latching current is dependent on lamp wattage. Too little current will neither gate on nor latch the thyristor.
8, If you were sucessful, then open the circuit and close again. The lamp shall stay dark until you touch gating wire momentarily to anode, which shall light the lamp again.
Sounds awfully complicated. But can be done in a few minutes if you have a 12 V DC supply and a 5 - 50 W lamp available. For smaller thyristors, you shall use lesser wattage.
Please note that this does not check nominal blocking voltage and reverse voltage. For that, you need a full-blown thyristor checker.
Gunnar Englund
100 % recycled posting: Electrons, ideas, finger-tips have been used over and over again...
