How to stop Task Scheduler?
CADGemini
Hello All,
I need someone's help on this. I ran a task to update files in my design library. But forgot to set the time for after work hours. I would like to stop the task and create a new one for later in the day. I went to Task scheduler already and deleted the task from the list, along with all the sub-tasks. It is still cycling through all the files and saving them in 2006.
How can I stop the task?
P.S. It also really annoying that it has to open and close solidworks to perform this kind of task. I wish that it would just keep solidworks open while doing this. It is starting to give me a headache looking at the screen flashing all the time.
Any help anyone can provide would be appreciated.
Best Regards,
Jon
Challenges are what makes life interesting; overcoming them is what makes life meaningful.
Solidworks 2006 SP0.0
Stop the process in the Task Manager.
or
Pull the plug?
[cheers]
Helpful SW websites every user should be aware of faq559-520
How to get answers to your SW questions faq559-1091
I understand it may seem annoying if we run TScheduler on regular working hours, but the opening and closing of SW has two purposes: to avoid irregular updates of similar files in different folders and to close the process if needed. Check that there is a period of time you can configure to kill SW, if it hangs.
Daniel
PS: there is always a SWBoengine procees runninh. stop that process
careful stopping it with Task Manager, it messed up all my SW settings after I did that. VAR said it is a bug.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP3.1 / PDMWorks 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
Thanks to All,
I took an early lunch and by the time I got back the task was done. I hope that they can improve upon the task scheduler in future releases.
Best Regards,
Jon
