Hi Tuw,
Thanks for the response!
Unfortunately, Rod elements won`t give the proper results (I don`t need compression at all).
Maybe it is possible somehow to disable the "compresssion" property in rod element. In such a way it will be an ideal element for me.
I need to simulate displacements of the scheme (I`ve attached the rough sketch).
There`s no difference for me what kind of the solution to be used for the analysis.
It is just necessary to get the proper values of displacements.
MStas
