K
kulibyaka
Guest
Consult please on a following question. It is necessary in Ansys to solve electrodynamics problem. The problem description (2D statement): is available opened yoke (for it magnetic permeability was set only, it was described by element PLANE13) with the coil (for the coil which was described by element PLANE53 and CIRCU124 magnetic permeability and specific resistance of a material was set). The constant magnet (for a magnet magnetic permeability and coercive force was set) is brought In a air gap of the yoke during some time interval (from 0 till 0.04 s). It is necessary to define as voltage and a current in the coil changes in due course. Has actually rested against a problem of the task of the movement of a magnet. How it to simulate? Tried to break all interval of time into some steps and on each step connected degree of freedom AZ for corresponding pair of knots (command CP), however at calculation the error took off. If somebody knows as to simulate movement in electrodynamics problem in Ansys, the huge request to impart experience. Thanks! Excuse for my English, I from Russia.
