Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpenUI
Module changeColorOfPreSelectedFaces_v2
Dim theSession As Session = Session.GetSession()
Dim sel As Selection = NXOpen.UI.GetUI.SelectionManager
Sub Main()
'' The selectFaces method takes an NXobject array by reference
Dim selectedObjectsArray() As NXObject
Selectbody(selectedObjectsArray)
'' Need to recast the face NXObjects to Displayable objects
Dim faceArray(selectedObjectsArray.Length - 1) As DisplayableObject
For i As Integer = 0 To selectedObjectsArray.Length - 1
faceArray(i) = CType(selectedObjectsArray(i), DisplayableObject)
Next
Dim changeBodytransluency As DisplayModification = theSession.DisplayManager.NewDisplayModification()
With changeBodytransluency
.ApplyToAllFaces = true
.NewTranslucency = 40
.Apply(faceArray)
.Dispose()
End With
End Sub
Sub Selectbody(ByRef selectedObjects As NXObject())
Dim ui As UI = NXOpen.UI.GetUI
Dim message As String = "Select body"
Dim title As String = "Selection"
Dim scope As Selection.SelectionScope = Selection.SelectionScope.AnyInAssembly
Dim keepHighlighted As Boolean = False
Dim includeFeatures As Boolean = False
Dim response As Selection.Response
Dim selectionAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific
Dim selectionMask_array(1) As Selection.MaskTriple
With selectionMask_array(0)
.Type = UFConstants.UF_component_type
.Subtype = UFConstants.UF_component_subtype
.SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_BODY
.SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_SOLID_BODY
End With
With selectionMask_array(1)
.Type = UFConstants.UF_solid_type
.Subtype = 0
End with
response = ui.SelectionManager.SelectObjects(message, title, scope, _
selectionAction, includeFeatures, _
keepHighlighted, selectionMask_array, _
selectedObjects)
If response = Selection.Response.Cancel Or response = Selection.Response.Back Then
Return
End If
End Sub
Public Function GetUnloadOption(ByVal dummy As String) As Integer
GetUnloadOption = NXOpen.UF.UFConstants.UF_UNLOAD_IMMEDIATELY
End Function
End Module
