How to send Drawings with RText to Lite Users
duck0601
61
I work in an environment with both ACAD2k and ACAD2k lite users. I use RText to generate drawing numbers in the template files I created (based on filename). However, when I send the drawings to someone with Lite, it shows as an x'ed box. Is there a way to embed this information so that the lite side can utilize this, or will I have to abandon my automation.
Thanks for your help
You can explode RTEXT into MTEXT and it keeps the info you want (it doesn't show the diesel expression). Do this when you BIND your drawings to send to LT users. if you have several RTEXT objects use QSELECT to get them all and explode 'em.
Thanks for your help and also for your additional commands.
