how to save model display settings
  • Thread starter Thread starter wildfirebrigade
  • Start date Start date
W
wildfirebrigade
Guest
changed settings in: view --> Display settings --> Model
display are NOT saved when I restart ProE WF5. How can I
achieve this?
I would like to disable "animation while reorienting" and
use "smooth lines".
I saved tree.cfg and syscol.win but no luck.
Both options can be set by using a config.pro option
Tools-Options
In the options box type Smooth_lines, value yes
then Max_animation_time and set it to 0
Now save the config.pro file and you are set.
It works!
Thanx alot.
