how to run .exe file in nx C# windows external application
dhaval082
26
dear sir
i make one one journal file and the convert this file into .exe file ,now when i run this .exe application in nx open module in nx that's
working fine but now i required to run this .exe file directly from C# windows external application.
how to run this ? please guide me[
[[/i]/b][/i]
It sounds like you will need to utilize the remoting that Siemens have made available. You will find an example in the UGOPEN/samples. It basically starts up NX with a port open. This port allows you access via an external program. I would start off with simple things like opening a part just to try and make the link.
I have a problem. when I try to Debug visual basic 2010 with nx8open, show me an error : a project with an output type of class library cannot be started directly.
How can I solve this problem?
Sidiclei
dear sir
i required to code for the run .exe file in nx open.code required in C#
Dear Srs.
I have this problem when I try to debug my program by Visual Basic using NXopen.
Could not load file or assembly 'NXOpen, Version=8.0.3.4, Culture=neutral, PublicKeyToken=null' or one of its dependencies. O sistema não pode encontrar o arquivo especificado.
Could you please help with this problem?
