A
Azizi
Guest
I want to reverse engineer a engine casing. I want to model in Pro/e. I have heard the best solution is either to use CMM or scanner to take the dimensions. Can anyone explain whether to use scanner or CMM method. By the way it is a single cylinder, two stroke glow ignition engine.
