How to relink Catproduct to Catia drawing 1
man2007
Aerospace
Nov 6, 2007
283
I want to know how to replace Catia Drawing link from CatPart to CatProduct.
I used File->Dsk... to relink but I am getting the error like "The link refused the document"
I am having the same problem with linking. I get the link refused by document error as well. The exception is that I am relinking between 2 catparts. Is there special "rules" that allow you to link or relink? I have read that you can't use generative views to do it, among other things.
catiajim is right. you cant do relink a drawing. You have to recreate the drawing
Catiajim has forgotten more than most of us know, he might have been mistaken on this one. I might as well recreate the drawing if I had to check every dimension.
The original question was relinking from a CATPart to a CATProduct. Does that workaround work for this case? I can understand how it would work from CATPart to CATPart or CATProduct to CATProduct, but not how it would work from CATPart to CATProduct or vice versa.
Thanks for the complements :)
