How to read a vibration analysis report
dharhay
29
I received a vibration analysis report on gearmotors from a customer. There are many parameters such as position, direction, location, units, filters, detection. Also a graph .
Is there any available whitepapers or primers out on the net that I could read prior to calling and asking to speak to the technician concerning the results? Thanks.
Dave Harhay
Bronx, Taylor-Wilson
North Canton, OH
Just a suggestion, repost this in "Mechanical Acoustics/Vibration engineering Forum" and also if you can post the report, maybe others can comment on what you have.
Tobalcane
"If you avoid failure, you also avoid success."
Hi dharhay,
google "commtest vibration primer" the first result is a downloads page.
On that page there is a beginner's guide.
It will help with most of your questions if I remember correctly.
I'm sure other companies have these as well.
Regards, MM
I realized my posting error as soon as I pressed the enter key!
Thanks for your suggestions.
Dave Harhay
North Canton, OH
