ProtectiveBoy
- Sep 24, 2008
- 5
I want to plot the R-X diagram for distance relay using MATLAB.
I have series of currents and voltages as follows:
1. Current, I
2. Voltage, V
In order to obtain impedance, I should calculate Z, i.e.(Z=V/I)
Question:
1. Should I calculate impedance,Z equal to |V|/|I| ?, or
2. Should I calculate impedance,Z equal to |V/I|
*|V| means magnitude of voltage
3. From my understanding, the function of relay is comparing between 'impedance setting' and 'impedance seen'.If 'impedance seen' less than 'impedance setting', then the relay will pass trip signal to circuit breaker.
But impedance consists of real and imaginary parts, Z=(Real part) + (Imaginary part);
Therefore which part should I compare ?
regards
1. Current, I
2. Voltage, V
Question:
regards
