Alexander888
Can anyone know how to append preselected items to a geometrical set?
Basically macro should take the preselected items and then place them in a new Geo Set called 'CG' and put this 'CG' geo. set into the item's parent Geometrical set.
In other words, we will select items in the tree that are inside a geometrical set. We run the macro. Macro will create a geoset called 'CG' inside the parent geoset, and moves all selected features into this 'CG' geo set.
This is my current code that is not working.
Error message says that the method AppendHybridShape failed at line 40 col. 8.
Thanks for the help in advance. Got stuck here badly.
Code:
Sub CATMain()
' Get the CATIA application object
Dim CATIAApp
Set CATIAApp = GetObject("", "CATIA.Application")
' Get the active document
Dim doc
Set doc = CATIAApp.ActiveDocument
' Get the selection object
Dim selection
Set selection = doc.Selection
' Ensure that items are selected
If selection.Count = 0 Then
MsgBox "Please select geometrical items."
Exit Sub
End If
' Get the first selected item to determine the parent geometrical set
Dim firstSelectedItem
Set firstSelectedItem = selection.Item(1).Value
' Find the parent geometrical set
Dim parentSet
Set parentSet = firstSelectedItem.Parent.Parent
' Create a new geometrical set called 'CG' inside the parent geometrical set
Dim hybridBody
Set hybridBody = parentSet.HybridBodies.Add
hybridBody.Name = "CG"
' Loop through the selected items and move them to the new 'CG' geometrical set
Dim i
For i = 1 To selection.Count
Dim selectedItem
Set selectedItem = selection.Item(i).Value
' Append the selected item to the new 'CG' geometrical set
hybridBody.AppendHybridShape selectedItem
Next
' Update the document to reflect the changes
doc.Part.Update
MsgBox "Selected items moved to new geometrical set 'CG' inside " & parentSet.Name
End Sub
